How to delete multiple components at once?
Before the upgrade to the 1.75 version we could delete multiple components at once in a job by selecting them via shift+select. Now, even if the different components are well selected and can be copied at once, we can only delete them one by one.
Is there another way to remove part of the flow ?
Hello @sophie.nevanen
Thanks for your post, can you kindly confirm the full version number you are on please?
Thanks Joe
Hi Joe, we are currently using version 1.75.0.
Hi @sophie.nevanen​ it was fixed now in 1.76.2 you can also upgrade your matillion to latest version 1.76.3 but in that latest version there small downgrade if you are using Mongo component it will got deprecated you need change that component with new Mongo component.
The team have informed me that this will be resolved in the 1.75.13 release due soon.
