Ingestion : IMAP/Oauth2 with/out TLS authentication explanation
Hello Amazing people !
We are using Matillion ETL VM over azure.
We would like to know a couple of questions :
QUESTION: IMAP/Oauth2 plugin is operative and supported ?
QUIESTION: Can we setup a TLS certificate for the SSL tunnel at Matillion VM Level ?
For QUESTION: IMAP/Oauth2 plugin is operative and supported ?:
If you are trying to use gmail query, it is supported.
you can check here:
https://docs.matillion.com/metl/docs/2887499/#overview
No we are trying to connect using Azure Office 365 Account
