You need to remove columns from the column mapping drop down list that are allready chosen and make the scrollbars larger (sample window)
Hi @rka1621004583744,
Thankyou for sharing the suggestion. It sounds useful, but would you mind adding it to the Matillion Ideas Portal with a bit of context (i.e. which dropdown list do you mean), and ideally a screenshot?
Thanks in advance,
Ian
Done
Many thanks, confirming it's in the system!
Ian
