Setting up Oracle CDC following Matillion docs. When attempting trasnfer to Snowflake getting numerous ORA-06512 errors on SYS.DBMS_LOGMINER_INTERNAL, wht are we doing wrong?
Pipeline Error: [class java.sql.SQLSyntaxErrorException] ORA-00904: "BUILD_OP": invalid identifier ORA-06512: at "SYS.DBMS_LOGMNR_INTERNAL", line 8651 ORA-06512: at "SYS.DBMS_LOGMNR_INTERNAL", line 4519 ORA-06512: at "SYS.DBMS_LOGMNR_INTERNAL", line 2069 ORA-06512: at "SYS.DBMS_SQL", line 1134 ORA-06512: at "SYS.DBMS_LOGMNR_INTERNAL", line 2026 ORA-06512: at "SYS.DBMS_LOGMNR_INTERNAL", line 4493 ORA-06512: at "SYS.DBMS_LOGMNR_INTERNAL", line 8429 ORA-06512: at "SYS.DBMS_LOGMNR_INTERNAL", line 8665 ORA-06512: at "SYS.DBMS_LOGMNR_INTERNAL", line 8821 ORA-06512: at "SYS.DBMS_LOGMNR_D", line 61 ORA-06512: at line 1 [class oracle.jdbc.OracleDatabaseException] ORA-00904: "BUILD_OP": invalid identifier ORA-06512: at "SYS.DBMS_LOGMNR_INTERNAL", line 8651 ORA-06512: at "SYS.DBMS_LOGMNR_INTERNAL", line 4519 ORA-06512: at "SYS.DBMS_LOGMNR_INTERNAL", line 2069 ORA-06512: at "SYS.DBMS_SQL", line 1134 ORA-06512: at "SYS.DBMS_LOGMNR_INTERNAL", line 2026 ORA-06512: at "SYS.DBMS_LOGMNR_INTERNAL", line 4493 ORA-06512: at "SYS.DBMS_LOGMNR_INTERNAL", line 8429 ORA-06512: at "SYS.DBMS_LOGMNR_INTERNAL", line 8665 ORA-06512: at "SYS.DBMS_LOGMNR_INTERNAL", line 8821 ORA-06512: at "SYS.DBMS_LOGMNR_D", line 61 ORA-06512: at line 1
Hi @mikerault
I hope you are well, I can see you were advised to raise this as a support case with our team, was you able to get this done and the issue resolved?
This was for a client, they got the Matillion folks to respond and found the issue.
