How do I grant a user read only permissions to one or more projects?
We have a production Matillion server (Redshift) that is only accessible to certain teams within our organization. I would like to allow other teams the ability to log into this server and view jobs, history, etc. It would be read-only access to the projects.
Can someone please give me some guidance on how to enable read-only access to users? What's the simplest way to accomplish this?
Thanks in advance,
Andrew
Hi @ABate​, as far as I know there isn't really a way to set read-only on a project level basis. I know you can do it globally but I don't believe it's possible to do this at the project level. If no one else responds and support says it can't be done in the current product, I would submit it as an Idea in the Ideas Portal. I know this probably isn't the answer you are looking for but I hope it gives you some direction.
Thanks for your help, @Bryan​ . I will dig into the docs and try to figure out how to make all projects read-only on a global basis for now.
It does look like there's a feature currently under development to enable this, so that's great news - https://metlcommunity.matillion.com/s/idea/0874G000000kAmJQAU/detail.
