Is there any way to give access to an user at a project level in Matillion tool
Is there any way to give access to an user at a project level in Matillion tool.
Hi, If you open the project, expand the Project menu, and select "Manage Project". This should open a screen where you can select which users have Access and Admin permissions against the project.
Hope that's useful!
Thank you for the response. I'll check it
